HPD Ignition
Old Jun 22, 2005 | 11:59 PM
CED's Avatar
CED
Default HPD Ignition
Well i just finished installing the new ignition from HPD.The installation is pretty easy.The only complaint that i have is the tab's on the igniter coil,you have to solder a wire to each end.These tab's are very very cheesy,they both came loose from the igniter coil.I solder all day long at work,so i would say i can solder pretty good.I had some epoxy that i mixed to get the tab's to hold.I believe Rick had the same problem with one of these products.Once the epoxy cured i was able to take it for a spin,i gapped the plug at 35 and it pulls very strong,oh yeah don't get your son to pull the rope while you hold the cap either.It has a very strong spark,i just had to try it.[img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img][img]i/expressions/face-icon-small-frown.gif[/img]
Old Jun 23, 2005 | 01:28 AM
ScramaDamaDingDong's Avatar
so was it worth it. Do you reccomend it to the masses. is it quicker, smoother, more efficient or what. I have had my eye on one for a while, does it put out greater amperage for those of us who like to see where we're going and where we've been
Old Jun 23, 2005 | 02:34 AM
duneaholic's Avatar
It just lets you run a bigger gap and has more spark than the stock ignition. The stock one is pretty weak. It is really supposed to help on overall power. Mine does tend to misfire some. I believe this ignition will help eliminate that. I just can't afford one right now. Trying to save for a new house. I know I got my priorities all screwed up.[img]i/expressions/face-icon-small-tongue.gif[/img]
I don't think the cdi will have anything to do with the lighting circuit. If you want more light then look into getting a higher output stator so you can run more lighting or higher wattage bulbs.
Old Jun 24, 2005 | 02:15 AM
What are you thinking man you can't ride a house[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jun 25, 2005 | 03:25 PM
scramblered's Avatar
so what the HPD ignition mods is?
new stator plate? coil?
i run the race flywheel with a brand new oem 03 coil,what can i do t
get more spark fire then?,,thanks for any inputs i'm espicially working in that area those time ride,later.
Old Jun 25, 2005 | 04:35 PM
CED's Avatar
CED
You get the CDI,Coil and the igniter coil that goes on the stator plate.It is at least 3 times the spark of the stock ignition.
Old Jun 27, 2005 | 01:32 PM
thanks a lot for the info man,any ideas on the prices so far?
Old Jun 27, 2005 | 10:54 PM
Whitedog's Avatar
Its around 300 bucks
Old Jun 28, 2005 | 09:17 AM
O K ,that cool,i just went to the website i saw all the amazing new thing
in there.
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
