whats some issues with raptors?
well you will hear of alot of tranny problems. Some dont though, mine hasnt, although lots do.
Carb boots pop off and rip
Carbs are sometimes problems
Crappy suspension
My rear shock blew already and i havent rode it very hard....(might be a personal problem though not notorious)
Rev limiter
anything else guys??????
Crappy suspension
Rev limiter
Reverse switch is easy to break as is the thumb throttle. Replaced with a Dr D reverse lever and OEM thumb throttle from eBay. Tried the billet throttle, but the pull was too stiff.
Parking brake on older models is a piece of junk. Removed parking brake and installed block off plate.
The plastic dashboard falls off and the rubber things that hold it get lost. Replaced with TrailTech billet X-Bar clamp with integrated dash. ALso upgraded to larger dia. bars.
Stock gearing a little tall, dropped 1 tooth on front sprocket.
Misc bolts vibrate loose. Picked up universal replacement bolt kit, comes in really handy.
Stock footpegs a little small. Upgraded to AC Nerfs with pro-pegs.
Stock skid plates are plastic. I destroyed these things. Replaced with aluminum skids. Mangled the rear aluminum skid too. Would recommend going with steel for this one.
well we have plenty of tools.
the add in the paper said it has many extras. so that probably stuff to fix the broken stuff and what not. they havent called back yet so i have to wait to see if i will get it.
frames are weak
suspension too top balanced
don't run good without mods
carbs pop out if misadjusted
tranny explosion
one-way starter gear explosions
cam chain issues
reverse switch easily broken
choke lever broke easily
and a bunch of other stuff
if you havn't wasted your money...save it and buy something else
tranny explosion
cam chain issues
jason you have obviously ridden your quad hard. If you ride any quad as hard as you've ridden that one then you are bound to have some problems. mx happens to be the hardest on your quad anyways.
