BAD NOISE
Old Jun 23, 2005 | 11:21 AM
MRBIGBLOCK's Avatar
Default BAD NOISE
IVE GOT A HORRABLE NOISE COMING FROM THE REAR OF MY SCRAMBLER UNDER A LOAD AND SEEMS TO BE GETTING WORSE.I REPLACED THE CHAIN AND ITS LOSE NOW I QUESS IT STRECHED IM GOING TO TIGHTEN IT BUT IM AFFRAID ITS COMING FROM THE TRANSMISION.IS IT A BIG DEAL TO REPLACE THE CHAIN IN THERE?HOW MUCH O THE EXPLORER TRANNYS SELL FOR AND IS IT A BIG DEAL TO TO THAT SWAP?
Old Jun 23, 2005 | 01:05 PM
thewayout420's Avatar
Default BAD NOISE
did you look the sprockets over to be sure there isnt any missing teeth?
Old Jun 23, 2005 | 01:55 PM
MRBIGBLOCK's Avatar
Default BAD NOISE
YEA THEY LOOKED GOOD WHEN I REPLACED CHAIN BUT IM GONNA CHECK AGAIN
Old Jun 23, 2005 | 02:58 PM
ATVnRocks's Avatar
Default BAD NOISE
Needs a trans chain inside.
Old Jun 23, 2005 | 03:27 PM
MRBIGBLOCK's Avatar
Default BAD NOISE
HOW HARD IS IT TO REPLACE THE CHAIN IN THE TRANNY
Old Jun 23, 2005 | 03:31 PM
ATVnRocks's Avatar
Default BAD NOISE
2 or 4wd??? Also, don't use upper case to type in forums, it gives the sense you're yelling at peeps. 2wd isn't bad, 4wd takes longer.
Old Jun 23, 2005 | 03:52 PM
MRBIGBLOCK's Avatar
Default BAD NOISE
Sorry about caps everything i do at work is that way so its habbit.its 4x4 400.what do you know about the explorer tranys?is it a bay job to do the chain or more any tips? thanks for the help
Old Jun 23, 2005 | 04:26 PM
ATVnRocks's Avatar
Default BAD NOISE
Depends on your mechanical aptitude for the job, don't know about the exploder trans though.
Old Jun 24, 2005 | 02:10 AM
ScramaDamaDingDong's Avatar
Default BAD NOISE
on the explorer trans: I believe it is a simple bolt on job, from what I understand it goes right in. I couldn't Imagine a low range in my scrammy I can barely hold on as it is
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
