Is hub oil really motor oil?
Old Jun 24, 2005 | 12:54 PM
scottso's Avatar
Default Is hub oil really motor oil?
I have read a lot about alternative lubricants here - important to me cause I have no local dealers. I just read a post that hub oil is actually the same 0W-40 motor oil used in the engine. Anybody actually used the motor oil for the front hubs?
Old Jun 24, 2005 | 06:18 PM
CED's Avatar
CED
Automatic transmission fluid.
Old Jun 24, 2005 | 06:32 PM
scottso's Avatar
Thats what I read in a pile of posts. But then I saw this thread with "Philfixit" who claims to have worked at a Polaris powertrain supplier (in another post) saying otherwise.
http://forums.atvconnection.com/mess...ighlight_key=y
Old Jun 24, 2005 | 06:59 PM
CED's Avatar
CED
I have used this oil for quiet a while with absolutely no problems.My bike is a 96,maybe the newer ones require something different.Someone will chime in and set us straight i'm sure.
Old Jun 24, 2005 | 09:18 PM
polarisbear500's Avatar
the best thing to do is just order a quart of it off the net somewhere or get someone on here to send you a quart...PM me and i will see if i can help
Old Jun 24, 2005 | 11:49 PM
ScramaDamaDingDong's Avatar
I use Mobil 1 Synthetic ATV (automatic transmission fluid) and it works great for me
don't use regular motor oil
Old Jun 25, 2005 | 12:23 AM
RallyRider05's Avatar
are you talking about using moter oil for hubs or the other way around?
Old Jun 25, 2005 | 12:25 AM
They are talking about using 0w30 for the hubs.
Old Jun 25, 2005 | 02:19 AM
Polaris500HO4x4's Avatar
just use the polaris stuff.. made for the hubs... and its not too pricey
Old Feb 1, 2007 | 12:41 PM
diffinman's Avatar
My service manual from Polaris (2001 Sportsman 500) says ATF type F fluid can be used as a substitute to polaris fluid for the hubs. DO NOT OVERFILL. Plug is to be at 4:00 or 8:00 position before replacing the fill plug.
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
