Parking brake leaks down after setting
After setting the master cylinder lever lock on my 04 650le it loses pressure overnight ; but it works fine for brakeing, Was this type of master cylinder designed to hold pressure as a parking brake ? Had it replaced newone does the same as original leaks off after setting. Forgot to mention it leaks no fluid.
Besides anybody with a Marlin and and Arctic Cat isn't very bright. I just can imagine anyone having both a Marlin and an AC, the guy has got to be as dumb as a stick, or as me (i've only got 3 Marlins right now and 2 Cats) . And why aren't you a member over on the Marlinowners forum?
my 03 500 did the same and the dealer said that i should not use it for overnight parking.
that it will leak down and when you release it you will have to pump it up a few times to get it to come all the way up.
when i parked it on a hill or any time i parked it for a long time i would put a rock or something under the wheels.
i only used the park brake when i had it in my truck for short distances.
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
