400 trail head compression testing procedure
Old Jul 1, 2005 | 04:20 PM
conig's Avatar
Default 400 trail head compression testing procedure
I tested my compression today with a compression tester from autozone. since I don;t have the electric start I had to pull the cord to test it, Do I just give the cord one good yank or do I yank it acouple times?
here are the numbers I got.
one yank -90psi
multiple yanks- 120psi.
If im correct I should be seeing 150psi.
Old Jul 1, 2005 | 04:36 PM
braveops's Avatar
mine is only 125psi i was thinking of going to around 140-145 i forgot i think you have to hold throttle wide open aswell
Old Jul 1, 2005 | 05:10 PM
conig's Avatar
I didn;t hold the throttle wide open, but thats scary becuase that would make the reading even lower the 90.
Do I pull once or acouple times?
Old Jul 1, 2005 | 06:27 PM
duneaholic's Avatar
I pull mine around 4 or 5 times. Are you using the the longer adapter that sometimes comes with the tester? I used it on mine and got a way lower reading. When I took off the extension then it went up like 20 psi.
Old Jul 1, 2005 | 06:35 PM
conig's Avatar
ok well thats a higher reading and means my rattle may be something else.
Do I pin the throttle wide open or no? I guess I should of read the instructions.
Im wondering if my pings are related to timing, Im going to try retarding my ignition just to check.
Old Jul 1, 2005 | 06:42 PM
duneaholic's Avatar
Yeah I keep the throttle pinned wide open when cranking. It's easier to have some one hold it open while you pull.
Old Jul 1, 2005 | 06:47 PM
POLARISFREAK's Avatar
You can pull it as many times as you like to achieve the highest reading, but the quicker it gets to the highest reading the better shape the rings are in. If you're compression is still low you can put a capful of oil in it and then retry and see if the compression comes up, if so the rings are bad.
Old Jul 4, 2005 | 12:01 AM
Whitedog's Avatar
Yea, pull it till the needle quits climbing.
Old Jul 4, 2005 | 05:06 PM
conig's Avatar
well using the correct method, I get 149psi after 3 pulls so I guess its safe to say my bore is alright.
will the counter balancer make a noise that sounds like piston slap? I know its not the clutches as ther arn;t on the bike.
Old Jul 4, 2005 | 05:26 PM
duneaholic's Avatar
Have you tried using a synthetic oil? It seemed to quiet things down a little.
