New at this HELP!!!!
Old Jul 3, 2005 | 01:23 AM
3wheelinmaniac's Avatar
Default New at this HELP!!!!
I have an 84 Honda 200 dont know which type but its a 4 speed with hi,lo,and reverse.....anyway i bought for 200 bucks and rode it one day and the cam chain broke replaced it and now need help in getting it back in timing anyone have any suggestions...........................
Old Jul 3, 2005 | 01:33 AM
rooster3209's Avatar
Its easier for me to do than explain but I'll give it a shot.
Take the plugs out of your left engine case cover, pull the sparkplug so the engine turns over easier, then turn the flywheel bolt til you see the 'T' in the other hole in the flywheel cover and align its mark with the notch at the top of the whole.
Pull the gas tank off and remove the small valve covers. The cam 'lobes' should not be touching the rocker arms.
Assuming everything is ok there make sure your valve lash is right(.002-0.003"). Then take off the CDI cover and turn your flywheel counterclockwise a little til you see the 'F' mark and line its index line with the notch at the top of the whole. Do the index marks line up on the pulse rotor and pulse generator under the CDI cover? There should also be an air gap between the pulse rotor and pulse generator of 0.012-0.016".
Jeff
this is all the info i got from jeff when i was trying to retime my 85 200x i hope it helps
Nick
Old Jul 3, 2005 | 01:37 AM
ThrashAndCrash's Avatar
3wheelinmaniac
Are you able to e-mail me a couple pics of the trike????....then I could tell you down to which bolt to remove................
Old Jul 3, 2005 | 10:31 PM
not able to send pics at the moment
