Quick suggestions please! - '84 TRX200
Old Jul 3, 2005 | 08:06 PM
Opteron's Avatar
Default Quick suggestions please! - '84 TRX200
Hey guys
I'm about to take a vacation of a few days to a friends place. He says he has an '84 TRX200 out there. All I know is that it has been bored out. Not sure how much, but they call it "The 250" now. No, I don't know why anyone would bore out a TRX200.
Anyways, they say that now it won't start up. I was going to go out there and take a look at it. What all should I look for? I guess starting at grounding the plug and seeing if I am getting a spark would be a good starting point, also the fuel lines/gas tank.
Just wondering if anyone had any suggestions on what else to look for, etc. before I go out there and see what I can do. I'm still a beginner!
Thanks guys
Old Jul 3, 2005 | 11:49 PM
Opteron's Avatar
bump
Old Jul 4, 2005 | 12:57 AM
hondabuster's Avatar
Motors need three things to start.
Spark, at the correct time.
Compression.
Fresh gas.
If it hasnt been started in awhile, and gas was left in the tank...thats the first thing to change.
Then try getting spark, when it turns over, by holding the spark plug against the head. If you can see it, then its good enough. Assume its at the correct time, if the motor wasnt disassembled since it quit running.
If those check out, then a compression test is next. It should probably have 120 psi or more, for it to start.
Good luck.
Old Jul 4, 2005 | 01:39 AM
Opteron's Avatar
Thanks for the info.
Won't have a compression tester out there (let alone much of anything). I heard that if it can force your thumb off of the top of teh plug hole then it has strong, or strong enough compression. Sound right?
Old Jul 26, 2005 | 02:00 PM
Ya, kind of as a rule. But if you have gas making it to the cylinder, and have spark, itll either be compression or timing.
Its always tough on a freshly put together motor, theres so many things that could be put together wrong. Its a lot easier to get a motor running, that was known to run at one time.
Bring a tow starp, because that may be your easiest way to get it started is to bump start it. Have him put it in 4th, key on, and you pull him, with another wheeler or your truck, and go about 7 to 10 mph, and if its posible for the motor to start, this will do it.
Good luck, and let us know how it goes.
Old Jul 26, 2005 | 10:01 PM
MikeM's Avatar
tough
what's up with hijacking the post
see what happened to your post?
happened to me, I couldn't figure out why the word tough was a hyperlink
bogus
Old Jul 27, 2005 | 12:40 AM
rescuediver's Avatar
Originally posted by: propnut
tough
bogus
This thread was not Hi-jacked.
Polaris has signed up with ATVConnection.com to have the word "TOUGH" linked to it's site. So, whenever " tough " is typed in the forum. It automatically links. So, there is NO hi-jacking going on.
Dan- ATV Connection Forum Moderator
Old Jul 27, 2005 | 11:35 AM
Duneaddict's Avatar
Looks like hijacking to me!
Old Jul 27, 2005 | 02:07 PM
I saw that when i typed it yesterday, then didnt have enough time to figure out what was happening. What other little special words do we have going on?
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
toonces
Sep 5, 2015 01:14 PM
