Starter Removal 101
Old Oct 13, 2000 | 07:24 AM
Loyal's Avatar
For those who are interested in saving a few bucks with removing their own starter when it gives problems . . . here is the process I used last night. My dealer was going to charge me $120 (3hrs @ $40) + $70 parts to fix the starter. I will be taking mine to a local alternator/starter repair shop who will charge me $75 to repair the starter.
I would first like to thank everyone who gave me their two cents worth. I have brought all the info together and added some of my own experience to come up with a process that should be quite attainable for the everyday backyard mechanic.
Starter Removal (actual)
1) Securely raise the quad off the floor. I run mine up on 4 car ramps.
2) Remove seat and plastic side panels
3) Remove floorboard to get access to the recoil housing
4) Disconnect battery ground cable
5) Remove pipe. There is only three springs and one bolt and it gives you so much more room to play with. If you can get the Master Link out of the middle chain (I have a 96) do it, it will allow you to easily complete Step 6 - but it is not necessary
6) Remove recoil housing. I found mine a little stuck so I had to tap it with a rubber mallet. It is still stubborn, remove the airbox and tap it from behind
7) Remove the two starter bolts. I could not totally remove my recoil housing, but I shifted it to the right allowing me to gain access to the starter bolts.
8) Remove rock guard from the bottom of the quad
9) Remove starter cable.
10) Use 10mm wrench (long handle would make it easier) to remove the two short bolts attaching the starter support bracket to the engine
11) The starter should then slide out of the recoil housing through the bottom of the frame.
Starter Installation (theory)
1) Loosely assemble support bracket to starter. Bracket bolts must be loose as to allow installation of support brackets to engine bolts.
2) Install new gasket (Part 3085283 Ref #18 Grid #D11) and place the starter in place
3) Steps 11-1 above.
Hope this helps
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
