300EX oil overflow
Old Oct 13, 2000 | 11:43 AM
gimpbro's Avatar
I need any input on what would cause the oil to come out the overflow into the airbox on a '99 300EX. The overflow is slow, but will continue even when the machine is almost a quart low. It's not smoking, and doesn't appear to be getting any oil on the plug. The filter had a small amount of metal shavings, and the oil gets black within just a few hours of use. I would appreciate any ideas anyone has.
Old Oct 13, 2000 | 11:58 AM
95wolv's Avatar
Hey,gimpbro,
One possibility could be a bad ring letter cylinder pressure blow oil out of the crankcase, this would also explain the rapid oil contamination, have a compression test done to see if blow by is the culprit.
Hope that helps
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
OutRacing
Sep 3, 2015 07:49 AM
