need help crank case ment to be presurised?
[img]i/expressions/face-icon-small-confused.gif[/img]Hey All I Have A 150cc 4stroke i dont know much about 4strokes but is the crank case ment to be presurised?
ive taken a picture this pipe is free at the engine end but at the other end its blocked off, the pipe is clear so is there ment to be a breather? or is it ment to be presurised? where does that pipe goto? (i took the flywheel cover off but it was going behind the clutch in a different case).
cheers guys!
http://home.swiftdsl.com.au/~donohoeo/quad.jpg
cheers guys!
thanks buddy but the wires loose cos i took the black cover off and was still putting it back 2gether when i took the picture.
the bigger hose goes to the little hose u can see in the pic the bigger end that comes from the engine is going to the crank case and cos the other trany end is blocked it presurise's the crank case!
