ATV pulling=Raptor?
Old Jul 9, 2005 | 11:26 PM
adamnieman's Avatar
Default ATV pulling=Raptor?
We are going to have a ATV pull this year at our local county fair. I have pulled a 4X4 before, but now I own a Raptor. I want to pull it mostly just to help promote the event, but I don't want to sit there and dig two holes either!
I will be pulling in the 500-600 cc 2WD class with a limit of 1100 lbs. How the heck will I be able to out-pull a fat-butt Sportsman 600? Thats with the 4WD off by the way.
I have weights that I can use, I just need to fad up some brackets to hold them. Anyone out there ever pulled there Raptor before? Any help would be great. Thank you.
03 Raptor
HMF/Pro FLow/K&N
Razrs
PRM Products
Old Jul 9, 2005 | 11:28 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
some good sized paddles :-D
Old Jul 9, 2005 | 11:42 PM
86LT250RFatty's Avatar
you said 500-600cc class, but the raptor is a 660cc? but anyway, i would say if its in sand or loose dirt, get some straight paddles, or a meaty tire and run like 1-2l psi. also, set the back shock to as soft as possible so that the back end squats to get more traction. Good luck man!
Old Jul 10, 2005 | 12:55 AM
ElectricShift's Avatar
Just curious where you're going to put the chain because the raptor has no hitch.....
Old Jul 10, 2005 | 01:26 AM
RapDaddy660's Avatar
i dont think anything will be as good as a 4 wheel drive quad for somethin like that...but hey i could be wrong...paddles from you know where! lol
Old Jul 10, 2005 | 03:29 AM
HughJazz's Avatar
I think you will have a heck of a time keep the frt end on the ground
Old Jul 10, 2005 | 11:46 AM
lapeerbanshee's Avatar
thats what i was thinking also.
Old Jul 10, 2005 | 12:20 PM
UltimateAussie's Avatar
if he puts the weights on the font it shouldnt be so bad
Old Jul 10, 2005 | 01:38 PM
but then he wont get good traction on the back tires.
Old Jul 10, 2005 | 02:05 PM
Starky's Avatar
Using the raptor in a pulling contest is a bad idea unless you are pulling against other sport quads, but like Electricshift said, where are you going to hook up to. You don't stand a chance against a utility quad even in 2 wheel drive. You're either going to spin the tires or smoke the clutch. It just wasn't made for that.
