What do I look for when buying a used Raptor?
Old Jul 15, 2005 | 12:18 AM
WinterRules's Avatar
Default What do I look for when buying a used Raptor?
I might be going to look at a 2002 Raptor tomorrow...What should I be looking for? Is there anything specific that I should check out? Thanks!
Old Jul 15, 2005 | 08:27 AM
Gwinnwarrior's Avatar
Alot of times you can tell alot about a machine just by looking at all the rest of his/her stuff. If it looks sharp and they live in a run down shack with 28 cars in the driveway with washers and dryers all over the place.....it prolly aint a good buy.
-check the fluids
-check the radiator for leaks, cases for leaks, and anything else leaking.
-Check front suspension to make sure things arent bent or damaged
-check rims for dents or wobbles, and also roll it and watch the rear axle and rims for axle to be bent.
-check chain wear
-take it for a ride and run it through the gears fast and slow.....make sure it feels right shifting and driving.
-take a look at the plastics..but dont judge too harsh...yamaha plastics get white creases very easily in them.
-check tire wear
-another thing to check, is the air filter. normally a person will get the thing washed up nice but forget to clean the filter, if the plastics are nice and the filter is caked in sand......it probably wasnt cared for as well as you should.
-check oil, ask when he changed it, and watch for shavings on the dipstick.
-finally, lay down and check the bottom of the frame/bellypan.....normally it will be scratched up from grass, sand and gravel, but look for large cracks or dings, if the frame is cracked NO WAY!
Basically this is every single thing to check....not that it has to be checked though. Some people are **** about things.
Just use commen sense and good judgement and youll be fine.
good luck.....if its good get it, youll love the raptor man.
Old Jul 15, 2005 | 09:25 AM
Warrior02man's Avatar
make sure its an 02 raptor.. because the 01s have many problems. Check the 10th digit in on the serial number and it should be a 2 which means its an 02.
Old Jul 15, 2005 | 11:41 AM
DavidLT250S's Avatar
check the steering also make sure its straight and accurate
Ashley S
May 29, 2017 10:54 AM
GNorm
Aug 1, 2015 11:06 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
