i need some help asap
Old Jul 17, 2005 | 05:46 AM
papichulo's Avatar
Default i need some helo asap
So my chain was loose and i mean really loose like 2 inches of play so i went and bought a new chain and i went to put it on and it just barely wont fit. I loosened the two nuts on the back of the swingarm but i couldnt move the houseing forward or back. Am i missing something? Please get back to me asap cause i wanna ride in the morning. lol
Thanks in advance
Old Jul 17, 2005 | 06:06 AM
XtremeSkier's Avatar
Default i need some help asap
Thanks in advance
if it is the same tighting and loosening set up as mine there should be one more small screw that u need to unscrew, its on the rear disc break, its a small screw, its like upside down, kind of underneat the break, unscrew that, get a plumbers wrech and twist the axle
Old Jul 17, 2005 | 01:16 PM
ScramaDamaDingDong's Avatar
once you get it all loose you have to rotate the axle using the large hex area on the axle that will change your front and back distance
Old Jul 17, 2005 | 03:39 PM
jimmypsp700's Avatar
There are the two axel carrier bolts and two caliper mount bracket bolts facing down also, (not on the actual calip but where it mounts to) that need to be lossened.
Alternative method:
Stick a punch through the hole on the sprocket and push the machine forward to rotate the eccentric housing and take out the slack to tighten up the chain.
This is easier IMO especailly if you dont have an EXTRA large pipe wrench.
Jim
Old Jul 17, 2005 | 07:24 PM
papichulo's Avatar
well i got it on and all is good know. I didnt know about the caliper bolts and that was what was holding me back. Thanks for the help you guys.
slowgsxr97
Sep 8, 2015 07:33 PM
400H0
10
Aug 20, 2015 07:34 PM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
mitchxc700
Aug 10, 2015 09:26 PM
Daryl Devine
Technical and How-To Articles
Jun 8, 2015 08:59 AM
