250r exhaust leak
Old Jul 17, 2005 | 09:11 PM
Beefy400's Avatar
Default 250r exhaust leak
my pipe is leaking where the expansion chaimber part of the pipe connects to the straight pipe off the motor it is also rattling what do you think i can use that would help with the rattling and create a good seal?
Old Jul 18, 2005 | 01:35 AM
DragRaceKing's Avatar
Try using Permatex,I use this on all my pipes,even where it goes to the cylinder to prevent oil splatter on my beasts.This should also prevent the rattling noise by making a rubber-type sealant around the interior of the pipe,just becareful of getting it on the outside cause you dont wanna have to scratch the pipe to scrape it off.
Old Jul 18, 2005 | 12:39 PM
Beefy400's Avatar
where can i get that permatex
Old Jul 18, 2005 | 03:13 PM
Beefy400's Avatar
permatex makes a bunch of different products what one do you suggest i use??
Old Jul 18, 2005 | 09:52 PM
Well,Im not exactly sure but it is in the orange and white tube,and its orange sealant,its the best they make.
Old Jul 21, 2005 | 09:56 AM
Hoopie's Avatar
Its the permatex high temp. its in a orange tube.
Old Jul 21, 2005 | 08:46 PM
dragracer789's Avatar
Might sound dumb but, you do have a couple springs on there right?
Old Jul 22, 2005 | 01:02 PM
Beefy400's Avatar
ok im a dumb a** i tryed to use exhaust wrap to help fix the problem i wraped it around where the two pieces of pipe meet and it actually over lapped inside the pipe so innocently i folded it over inside the pipe.... i started the bike and it ran shi*tty so i took the pipe off and found out that the pipe wrap that was overlapped inside the pipe was ripped off so i just took it all off i did not start the bike since then do you think it is possible that i screwed up the motor because the pieces of muffler wrap are no where to be found inside the pipe i just hope it didnt get sucked back into the motor??? please advise
Old Jul 23, 2005 | 01:08 PM
Beefy400's Avatar
what u guys think?
Old Jul 24, 2005 | 01:50 AM
lbc's Avatar
lbc
Typical problem especially if you have an aftermarket exhaust. Unless you are loosing performance just deal with it. @#$% happens.
