Stuck in gear
Old Jul 18, 2005 | 02:01 AM
SPORTSMAN70003's Avatar
Default Stuck in gear
I have a friends 89 350 honda 4x4 that I'm going to fix and he is have a problem with it hanging in gear ( all gears ). Is there any adjustments that might help?
Old Jul 18, 2005 | 04:47 PM
robnhouston's Avatar
Number 1 make sure the clutch is in proper adjustment.
Old Jul 18, 2005 | 06:16 PM
Where do I adjust the clutch at?
Old Jul 18, 2005 | 08:53 PM
snowbuster's Avatar
bump
Old Jul 19, 2005 | 12:32 AM
hondarulesinnc's Avatar
Since it is such an old model it is an overhead cam design so that means the clutch will be on the side of the motor so the adjuster should be somewhere on one side of the engine it will kind of be recesed into the side of the engine and it will look like a bolt with a flat head screw in the middle of it. It should say increase and decrease play around the bolt, but if not you should be able to loosen the lock nut and turn the screw clock-wise to decrease the tension on the clutches witch should help the shifting, but not too much because it will cause the clutch to slip. Make sure you don't let the screw move while you are tightening the nut or you will have to start over.
That is about everything there is to know about adjusting the clutch, I hope this helps and I hope you have you a good fourwheeler to fix up.
Good Luck
Old Jul 19, 2005 | 01:57 PM
Forgot....step 0 - get a repair manual. Priceless info for about $25. Ebay a good place to start.
Njrider1230
Jul 29, 2023 05:16 AM
Polaris5
Aug 29, 2015 09:11 PM
heath legg
Jul 24, 2015 01:01 PM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
ghost civic
Jul 15, 2015 10:48 PM
