Fuses on 05 Predator
Old Jul 18, 2005 | 12:43 PM
Warrior8me's Avatar
Default Fuses on 05 Predator
My 05 Predator just stopped running yesterday. No elect power at all. We tried to pull start it, but still would not run. Is there a fuse and where is it? I am in North Carolina riding, but my book is in Ohio.
Thanks
Old Jul 18, 2005 | 02:53 PM
kmoney's Avatar
Im not for sure about a fuse but I had a simalar problem with my 04. It ended up being the battery shorted out. You might try hooking up your connections to some jumper cables and see if you have power.
Old Jul 18, 2005 | 08:18 PM
tatertodd's Avatar
Ya try the battery first. my positive cable came off when ridding about two weeks ago. I just put it back on with a zip tie and that got me through the weekend. Put a new bolt in after I got home and she was ready to go.
Old Jul 18, 2005 | 08:29 PM
Warrior8me's Avatar
Thanks for the answers, but those have been tried. I have two 05 preds, so I could swap parts to find the problem. I just wish I know where to start.
I guess the dealership will have to look at it tomorrow.
Keep some ideas coming.
Old Jul 19, 2005 | 11:58 AM
Fixitmatt's Avatar
Try the CDI
Old Jul 19, 2005 | 05:53 PM
Flynbryan's Avatar
Just had a similar problem. The positive battery cable had come loose from the terminal.
Also, check under the left side panel and you will find a little black pouch with a fuse/breaker in it. These sometimes go bad. Jump the terminals on the breaker and see if it fires. If so, these are easy to find in any autoparts store. Just take it with you so they can match it up with a replacement. Just another oddball stupid thing Polaris had to do to be different...... [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jul 20, 2005 | 02:33 AM
Warrior8me's Avatar
The dealer found the problem. It burnt a wire back by the battery.
Thanks for all the info. I will keep it in store away in my little head for anther day.
Lucas Bohanan
Sep 29, 2015 01:16 AM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
Elkaholic
Sep 6, 2015 02:44 PM
