Intake allen screws
Old Jul 21, 2005 | 10:00 PM
2BIG2BFAST's Avatar
Default Intake allen screws
Is there any tricks to getting the allen screw out that is on the top of the intake without taking off the motor mount. Its to hot so i am planning the dissassembly inside the house where its a frosty 70 degrees. The bike wont fit through the door so im gonna have to do it in the garage.
Old Jul 21, 2005 | 10:06 PM
OregonDunePatrol's Avatar
You have to use one of those ball tip allen wrenches so you can angle it as you unscrew it.
Old Jul 21, 2005 | 10:08 PM
DuneMe's Avatar
Ball end allen.
If that doesn't work. . . take the bottom two off and then with a rubber mallet hit the bottom right of the intake on an upstroke. That should be enough to knock free the allen.
Old Jul 21, 2005 | 10:58 PM
jackass650's Avatar
I have craftsman ball end allen wrenches and I had to buy a cheap ball end set from walmart to fit the angle for the single screw, for some reason the ball end on the craftsman did not allow it to work, but the cheap allen wrench works great on it, go figure
Old Jul 21, 2005 | 11:45 PM
2BIG2BFAST's Avatar
Dang you guys are good, thanks for the help. Last time i removed the motor mount, loosened the front ones, tilted it forward still did not work. ended up bending the crap out of the motor mount so i could get it out of the way so i could get to the intake. Let me see last time 2 and a half hours, this time two hours laying on the couch and 15 minutes to pull the intake off This is one of those priceless commercials. thanks again
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Oct 10, 2015 10:20 AM
Sassinm1
Sep 30, 2015 04:23 AM
Jackg17
Sep 26, 2015 09:30 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
