ball joints on 2004 sportsman help
Old Jul 25, 2005 | 05:14 PM
fwd1122's Avatar
Default ball joints on 2004 sportsman help
the a arm where it connects to the hubstrut assembly is really wobbley. Looks like the ball joint is bad. My question is how do I open up the hubstrut to replace the balljoint. If its not the balljoint what elsse could it be. I appreciate any help Thanks guys. Frank
Old Jul 25, 2005 | 05:40 PM
garrett5462's Avatar
might be wheel bearing.
does the wheel wobble from side to side or up and down? if its up and down then the wheel bearings are bad and if it wobbles side to side then he ball joints might be bad. just my $.02
Old Jul 25, 2005 | 05:52 PM
fwd1122's Avatar
just all kinds of play where the a arm attaches to the ball joint with the tire off the strut assembly wobbles
Old Jul 25, 2005 | 09:43 PM
paul700efi's Avatar
Sometimes the ball joint stud becomes loose in the A-arm. Pull the cotter pin and tighten the nut. If the nut was tight then the ball joint will need to be replaced. The ball joint job is easy if you use the ball joint replacement tool.
Old Jul 26, 2005 | 09:21 AM
NBsportsman's Avatar
Don't know how many miles you have on your Sportsman but if you greased the ball joints at all they should not be loose this soon. Like the others posted check the retaining nut, bearings and even the tie rod ends......
Old Jul 26, 2005 | 07:14 PM
fwd1122's Avatar
my 700efi has 775 miles on it. Both nuts that connect to the balljoints were lose. Is there any special amout of torque that I should apply to them. I tightened them and all the play went away... Thanks again guys.
Old Jul 26, 2005 | 11:35 PM
Torque to 25 ft/lbs....[img]i/expressions/face-icon-small-cool.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
velcro7279
Aug 24, 2015 01:15 PM
toonces
Aug 12, 2015 06:42 AM
musselmark
Jul 17, 2015 02:40 PM
