95 polaris sportsman 400 4x4
Old Jul 27, 2005 | 02:52 PM
ljrce's Avatar
Default 95 polaris sportsman 400 4x4
yes i have a 1995 polaris sportsman 400 4x4 new stator and flywheel and it will fire but not rev up or idle i need help as soon as possibale
Old Jul 27, 2005 | 02:57 PM
ATVnRocks's Avatar
Piston skirt broke off????
Old Jul 27, 2005 | 03:35 PM
ljrce's Avatar
yes iits not brooken
Old Jul 27, 2005 | 07:11 PM
ftwflh's Avatar
Check the engine compresion it needs to be 100psi min 120psi is better.
Old Jul 27, 2005 | 07:13 PM
ljrce's Avatar
its at 125
Old Jul 27, 2005 | 07:31 PM
ftwflh's Avatar
TRy cleanning the pilot jet in the carb.
Old Jul 27, 2005 | 07:34 PM
ljrce's Avatar
carbs rebuilt
Old Jul 27, 2005 | 10:38 PM
ftwflh's Avatar
Double check the pilot jet and check the intake boot for cracks.
Old Jul 28, 2005 | 06:54 AM
NascarFan's Avatar
I had a 95 400 before I went to a 500. I always had problems with the sparkplug. Just because they look good and are clean, does not mean they are working right. This was the main reason I went to a 4 stroke. If the timing is correct, don't overlook the little things like the plug.
One other thing that will kill a 400 2-cycle.............. a stopped up exhaust. Mine started running hot and crappy, overhauled the top end and that was no help. Took the muffler to be vatted out and it ran like new. Moral of this story is...what goes in, must come out. Good luck.
Old May 4, 2011 | 08:29 AM
ultraliter's Avatar
Default muffler vatting
Wher would you get your 1995 polaris sportsman 400 muffler vatted?
