Srammy picture help
Old Aug 2, 2005 | 07:55 PM
Bretman's Avatar
Default Srammy picture help
I got one of these digital cameras and i got my pics on the computer and when i try to put them on my file it sais they excede the size limit. One of them is smaller than the size limit and it still sais the same thing every time. Is there another way to do this or what.
Old Aug 2, 2005 | 08:12 PM
MnFriesen's Avatar
ok...I will try and help
First question is, how large is the file
what are the demensions of the pictures
and what type of file are you saving it as?
Old Aug 2, 2005 | 08:19 PM
Bretman's Avatar
dementions-2592x1728
Size-207kb
File-jpeg image., saved to my folder
There are more pics also that are bigger. I tried taking more also of my quad farther away.
Old Aug 2, 2005 | 08:49 PM
MnFriesen's Avatar
Photo dimensions are limited to 750 wide by 750 high.
Photo file size is limited to 150K or less.
Old Aug 2, 2005 | 08:51 PM
Bretman's Avatar
how do i fix this to make it work
Old Aug 2, 2005 | 08:53 PM
MnFriesen's Avatar
are you using windows or mac?
Old Aug 2, 2005 | 08:58 PM
MnFriesen's Avatar
ok if you are using windows, which I am assuming you are, open up "paint" its in the start up menu - all programs -accessories - paint
then you open up the file you want to load, then click on image, and then stretch scew use the "stretch" function and decress it by say 50 percent the first time...and then keep on doing it, slowly chaning it tell it is under the file size
Old Aug 2, 2005 | 09:01 PM
Bretman's Avatar
yes windows
Old Aug 2, 2005 | 09:24 PM
Bretman's Avatar
i tried opening it up in paint but the image was to big to put the box around it. Also when i open it up it doesnt even let me shrink it or nothing.
Old Aug 2, 2005 | 09:45 PM
xsmoker's Avatar
you don't need to see the whole picture,in paint just select "image" and in the drop down menu box select "stretch/skew". The boxes will have 100 in them, change them to like 25% length and width and save the image with a new name. Check the attributes of the file to see if the dimensions are small enough to be uploaded. If not, reduce the size another 50% and check again until it is small enough to be uploaded.
