Rancher ES Cold Start
Old Aug 3, 2005 | 10:46 PM
pinelog's Avatar
Default Rancher ES Cold Start
My Rancher ES is hard to start when cold. I have to use the primer valve. Is their a cure to this problem?
Old Aug 4, 2005 | 12:32 AM
LittleBill's Avatar
no they are all like this, good news is they start with that primer bulb down to -10F (tested) lol after that who cares
Old Aug 4, 2005 | 02:59 AM
ATV_MAN's Avatar
Cure?...sure....buy an EFI quad...LOL
But seriously it's normal to prime or choke 4 stroke engines when they are cold. Best thing to do is keep your engine serviced, like keep a new plug in it, and fresh fuel, and it will start no problem.
Old Aug 4, 2005 | 10:26 AM
ddrumman2004's Avatar
My Rancher fires right up without choking it now although I am sure that when the weather cools later on this year, I'll have to pull the choke out to start it.
Old Aug 4, 2005 | 01:59 PM
hondabuster's Avatar
The choke circuit might not be working properly. Does it start ok when warmed up ? Is this a totally stock motor? Air lid still on?
Heres a quick test....when the motor is warmed up, and idleing. Pull the choke on fully, if the motor runs real bad, or dies, the choke is working. If theres no change, then its not.
Does it have any other drivability problems? Hesitation, popping, sputtering?
It probably wouldnt hurt, to go 1/4 turn richer, on the mixture screw.
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
RedRancher
Jun 4, 2015 12:29 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
