Shock Wrench
Old Aug 4, 2005 | 01:09 AM
AKParatrooper's Avatar
Default Shock Wrench
The stock wrench that came with the machine broke while adjusting the suspension. is there any place I can buy a replacement that will actually work.
Old Aug 4, 2005 | 01:07 PM
Bear4570's Avatar
There are a couple of aftermarket ones available. You do know you are not suppose to have any weight on the wheels when you adjust the shocks, don't you. Otherwise you will break the wrench.
Old Aug 4, 2005 | 01:48 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Those things are crappy, they will break even with no weight on them. I just use a channel lock.
Old Aug 4, 2005 | 10:40 PM
jwoodsman's Avatar
Don't waist your money getting another one ,I broke the one I had the first time I used it ,I had all the wheels off the ground and had adjusted 3 out of 4 when it broke .
The best tool for the job is an automotive tie rod adjustment tool for alignments ,I think it's about $35.
Old Aug 4, 2005 | 10:48 PM
jwoodsman's Avatar
I found this on Ebay
OTC TOOLS No. 7097 TIE ROD ADJUSTING WRENCH 1/2" DRIVE Item number: 4565941388
Old Aug 4, 2005 | 11:06 PM
kwc's Avatar
kwc
stock tool bent first time I used it.. Channel locks work great..
Old Aug 9, 2005 | 02:28 PM
swampyjunior's Avatar
Channel locks works well, but if you go to your local store that sells gas operated water pumps you can puck up a tool called a spanner wrench. Or call and ask aound at hardware stores. Out here on the west coast Cenex and any Sthil saw shop carries them. Looks very similar to the spring adjustment tool since the spanner wrench is used to tighten the hose connections (from 1-1/2 to 3 inches) on water lines and pumps. I have two sizes a 12 inch and a 6inch. My brother picked them up for me I think together they cost 15 bucks.
Old Aug 10, 2005 | 07:51 AM
MrTommy's Avatar
That's funny... When I was adjusting our shocks, it was the shock that broke, not the tool.
Old Aug 11, 2005 | 01:16 PM
SPD522's Avatar
Mine bent the first time I used it too. I mentioned it to my dealer and he said their shop uses channel locks as the AC wrench is a POS.
Old Aug 13, 2005 | 11:05 AM
buckaroo50's Avatar
Broke mine too! My CAT dealer happens to also be a Yamaha dealer and gave me a replacment free, it was a Yamaha and made of steel instead of cast crap. I also broke some teeth off the shocks so they relpace them too with an up grade that has holes instead of tabs.
I also broke the rear foot brake housing twice so I just threw it away, so I only have the hand brakes, foot brake was so weak that the only use was to hold the machine in place, it couldn't stop a 10 speed bicycle. Some day I will put a "T" in the brake line and have brakes on both rear wheels instead of just on the left. I know it is a locked axle but the added brake will help. I also plan to reattach the foot brake but not with a cable but within the hydralic setup. A simple "T" in the line and if needed a second bowl... I think I can get most of the part of some used motorcycle. This way when I use the foot brake it will go for all fours instead of one rear. Might even put a right hand lever too... lol
exmotocrosser
Sep 26, 2015 08:18 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
