'01 400EX Carb / Fuel lines... Where does it go?
Old Aug 5, 2005 | 09:46 PM
ThaChad's Avatar
Default '01 400EX Carb / Fuel lines... Where does it go?
Hey all,
I have an '01 400EX... It was leaking fuel and i notice the small tube comming from the bottom of the float bowl on the bottom of the carb was just hanging...
Where is it suppose to be hooked up to? I looked on my Z400, and that tube runs into a nipple on the Swing arm (Not sure what that's all about) But any case... I don't see a nipple on the 400ex for it to plug into to....
So where does it go?
Thanks,
-ThaChad
Old Aug 6, 2005 | 09:23 AM
powerslider's Avatar
It's not supposed to connect to anything, just a drain or vent hose for the carb.
Old Aug 6, 2005 | 12:40 PM
ThaChad's Avatar
Any idea why fuel would be flowing out that hose? I had to turn the fuel "Off" to stop fuel from just draining out of that hose....
Old Aug 6, 2005 | 01:10 PM
emac's Avatar
would it richen up the engine or somthing if i clamped this hose off cuz mine leaks when i wheelie
Old Aug 6, 2005 | 04:41 PM
hondablue's Avatar
it leaks because its suposed to if it didnt your float bowl would overflow reulting in way too much gas getting sucked into your cyl....and blowing up your engine....if it leaks all the time its time for a carb overhaul ....it probably has a bad needle in the carb ....leakin while doing wheelies ....let it leak if the bike runs good when the front end is not in the air ....its designed as a safety DONT mess with it....
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
