is a bad solonoid repairable?
Old Aug 6, 2005 | 01:02 PM
emac's Avatar
Default is abad solonoid repairable?
u mite have seen my other post on my broken solonoid that cliks when i try to start my quad and wont jump off my truck. my question is there a temporary fix for this so i can ride for the next week until my part comes in
i have basic electrical knowledge and no air left in my lungs from trying to push start it in the street by myself. any reply would be apreciated. thanx
Old Aug 6, 2005 | 02:10 PM
hondabuster's Avatar
Default is a bad solonoid repairable?
You could just use a jumper, and jump the terminals of the soliniod, like people do on the old fords. Use a metal pliers, upside down, or get a chunk of heavy gauge wire. The soliniod is just a fancy name for an electrical switch, and you can just manually by pass it.
Old Aug 6, 2005 | 02:58 PM
KNOWSALOT's Avatar
The Facility
Here's another tip.....rather than buying the solenoid for the 400EX,... buy one for a late model Recon.
Part number is 35850-HM8-A41. It sells for under $20 where as the one for the 400EX sells for over $60!!! It is the same switch!!
The price difference is because Honda sources the 400EX switch from Japan. The Recon switch is sourced from here in the U.S.
Don't you just love this country?? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 6, 2005 | 09:24 PM
emac's Avatar
thanx guys im ordering 1 today.
so if the solonoid is just a switch could i just remove it completely for now and carry a piece of thick stereo wire to connect the 2 wires when i want to start it.
Old Aug 6, 2005 | 10:56 PM
recon99's Avatar
The best thing to do until you get the new solenoid is to leave the old one in there and just jump start it across the two large terminals on the top. If you remove the broken solenoid then the wires could short out on each other, and even worse short to ground and start a fire under your seat.
Old Aug 7, 2005 | 08:14 AM
broook's Avatar
A little tip here is to use an insulated screwdriver to short accross the "NUTS" not the terminals. That way you will be able to remove the nuts easily when you go to replace the solenoid.
Old Aug 7, 2005 | 08:59 PM
emac's Avatar
glad i waited on ordering the solonoid cuz when i jump the terminals of the solonoid it still doesnt turn over, and when i took the solonoid completely out and touched the wires i stil got nothing.
wat does this mean, o ya and this is all while my battery was hooked up to a charger that usualy starts it rite away
Old Aug 7, 2005 | 09:46 PM
broook's Avatar
Assuming you checked the main fuse and it is good, it could be your ignition switch or starter brushes.
Old Aug 7, 2005 | 11:11 PM
recon99's Avatar
Does the motor crank but not fire, or is there nothing going on at all when you cross the solenoid? Did you put another fuse in after the last one blew? You need a good fuse in the holder whether you use the starter button or not, since that fuse supplies power to the ignition system. If the starter isn't even spinning then your problem is between the starter, battery, or the connections in between.
Old Aug 8, 2005 | 02:45 AM
emac's Avatar
ya the engine doesnt turn over at all i get nothing. i didnt get a new fuse tho i knew nothing about that, guess ill be getting 1 tomoro.
