686 VS 690 Hp numbers on raptor
Old Aug 10, 2005 | 11:40 AM
Dwags's Avatar
Default 686 VS 690 Hp numbers on raptor
i an in the middle of pulling my motor out and i want to have the most hp and i have to be under 700 for racing. And what company to use, Craycraft, Trinity, LRD. Thanks yall.
Old Aug 10, 2005 | 03:13 PM
CTracingraptor's Avatar
686/690 are the same thing, just called different.
Look into a craycraft, kenz or sparks.
you can make around 70+hp on a well built 686/690
Old Aug 11, 2005 | 12:59 AM
bad350twin's Avatar
i havent seen or heard of many 70+hp all motor 686's anywhere.... but you can definitely achieve low-high sixties
Old Aug 11, 2005 | 01:28 AM
MasterRaptor's Avatar
What parts do you need to get high 60's?
Old Aug 11, 2005 | 02:57 AM
ItalianStallion's Avatar
The whole thing...The cam will make the difference. I pull 60 h.p. with a stage 2 hotcam and a low compression piston...10.75 to 1. and I also use 87 octane . You could get a higher number if you used a 11 or 12 to 1 piston, high octane fuel,balanced crank with a new light weight rod, 102 mm bore and a good port and polish. There are a few other little things like valve work, springs, teflon or ceramic coatings for heat distribution and longevity of the motor, carb rework or a new set of FCR's. JMO. Trinity to me does not play the speed game as well as Craycraft, Kenz or Sparks. Those would be my top three picks. Either one will answer all the questions you have.Videos of my quad in action...from stock to a 686.Nuthin fancy.
Old Aug 11, 2005 | 10:29 PM
70hp is easily achievale on a well built...key word here is a well built 686.
massive porting,
686 bore
lightweight rod
balanced crank
FCR's carbs
huge drag cam
and correct exhaust
mrhp makes 70hp on his stock bore ds650
and kenz is around 67 on his stock bore raptor...
Old Aug 11, 2005 | 11:23 PM
Ernie660R's Avatar
You have to remember MrHP nor Kenz got those numbers by not running 87 octane pump gas.... Lots of funny fuels....[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 12, 2005 | 12:15 AM
vp110, i dont care what gas they run and long as they get those numbers on GAS, it might not be from the pump, but it sure aint running those numbers on ethanol, methanol or nitro.
Old Aug 12, 2005 | 02:02 AM
CountryJoeGlass's Avatar
Ernie @ 4SW-4 MrHP took 1st place in 500cc above stock bore with race gas only. MrHP took 2nd place in the builders class with his stock bore 650 motor on race gas. GP racing took 1st place builders class with the big bore stroker 780 raptor. MrHP's stock bore DS is putting out about 78HP on race gas. It's not pump gas but not funny fuels, just race gas. The other HPR bike take 2nd in the open 500cc above class on race gas only.
Old Aug 12, 2005 | 10:40 AM
exactly.
