A-ARM BUSHING
Old Oct 18, 2000 | 09:04 PM
mudmagnum's Avatar
Today I was going over my Quad and the brass- looking bushing was gone. Do they bust off or what? Has anyone ever had this problem? If so, how hard are they to replace?
Old Oct 18, 2000 | 09:46 PM
Farmr123's Avatar
Never broke one. I guess they do sometimes. They are very simple to replace. Block up the frame, remove the 2 bolts where the A-arm hinges, swing the A-arm out enough to pop out the new bushings, slip the new ones in, & tighten it all up. On a 4-wd machine, be CAREFUL so as not to let the CV joint seperate. Also might be a good idea to put in new bolts, too. Whatever broke the bushing may have put a hairline crack in them. Shouldn't take over 15 minutes or so.
Old Oct 19, 2000 | 02:01 AM
Lurch77's Avatar
Those fitting are known to break. I believe Polaris is using something different now. Check to make sure you have no bends on the arm. This can cause binding on the bush, and cause it to fail. But I doubt you have a bent arm. Like I said, these bushings are not known to be strong.
Customer Service #1
May 15, 2020 08:46 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Alex G.
Sep 19, 2015 06:34 PM
cdstang
Aug 31, 2015 07:52 AM
