Aftermarked CDI - 87 or 91 octane?
Old Aug 12, 2005 | 07:44 PM
400EXerciser's Avatar
Default Aftermarked CDI - 87 or 91 octane?
If you were running 87 octane in your DS to advance the timing did you find that when you went with an aftermarket CDI you had to go back to 91 octane. Would this be true if you were running a Procom CDI that seems to add to much advance to early in the rpms? Would the 91 octane help? Not that I think the advance is the same for White Brothers and Big Gun CDI's but what about them? I am wondering if twenty cents more for 91 octane is a little insurance against kick back on these units or am I all wet in my thinking. Just a thought and I would like to get your imput. Thanks
Old Aug 12, 2005 | 08:36 PM
ILivSD's Avatar
Hey 400EXerciser,
I was kind of thinking the same thing... as I run 91 octain Union 76 gas all the time and have had vary little if any problmes (knock on wood) with my Procom CDI unit.
I am wondering if the combination of 87 octane and the CDI from Procomm may be a bit to much for the timeing ?
ILIVSD
Old Aug 13, 2005 | 01:09 AM
BlackHawk's Avatar
I don't believe that a CDI box makes a big enough change in timing to worry about chaing octane. At least when I tested that theory with my Vortex I saw no change.
Old Aug 13, 2005 | 01:29 AM
Oldmanracing's Avatar
Has long as your total timing is 26 degree's and you have stock compression, 87 is fine.
If you raise your compression or advance your total timing above 26, then run 91.
Old Aug 13, 2005 | 01:41 AM
choosetolose04's Avatar
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 13, 2005 | 11:39 AM
Thanks, makes sense. Its the total advance that can cause the problems. The CDI only advances the timing on bottom and mid I guess, leaving total advance at factory specs? I know that in my rail I took and advanced the timeing on the distibutor on the bottom but then modified the distibutor so I would not get more than a total of 32 degrees total. This gave me more bottom end yet did not go past the spec sheet for total timeing on the cam and compression I run(no spark knock). I guess the aftermarket CDI does the same.
Polaris-400
Aug 19, 2015 02:20 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
ranvette
Jun 10, 2015 09:57 PM
Tree Farmer
May 6, 2000 03:36 AM
