Belt clearance side to side.
Old Aug 13, 2005 | 12:21 PM
Fastestdad's Avatar
Default Belt clearance side to side.
I have too much clearance from side to side on the primary clutch to belt. I havent measured it but its over .080. I have 10-58's and stock 55 gram weights. i use the 55's for 300 ft and 58's for dunes. How do you adjust the belt clearance side to side in the primary. New belt. Thanks.
Old Aug 15, 2005 | 10:50 AM
Speedwerx's Avatar
This is with a new belt correct? If you want to adjust this you will have to split the primary adn reshim the spider. You would want to take our the differance.
Old Aug 15, 2005 | 01:29 PM
Bubba297's Avatar
To use the 10 series weights you need to replace the stock clutch bolt washer with the larger thinner snowmobile washer. That will push the outer sheave in a little and get the correct weight position. That may be your clearance problem you speak of. Also if the sheaves are worn where the belt engages then that will increase clearance.
Old Aug 16, 2005 | 11:04 AM
scramblered's Avatar
no more than .020,and belt deflection at around 1 /1/8,
i use hot seat snowmobile washer spacer to get that tight clearance,
those are plastic spacer to be put between the clutch bolt and clutch cover to push it toward the rotor,they're 3 different wide spacer available.
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
braap123
Sep 7, 2015 10:57 AM
