Airbox Mods
Old Oct 19, 2000 | 12:00 PM
pol4X4's Avatar
I noticed some of you have "Airbox Mods" on your machines. Will someone please explain in detail the "Airbox Mod"? I have a 2000 Polaris Scrambler 400 4X4. Also, those with the same machine, was it worth it???
thankz,
darren
Old Oct 19, 2000 | 12:41 PM
TNT's Avatar
TNT
I would also like here about these mods for my 400 sportsman.
TNT
Old Oct 19, 2000 | 12:59 PM
waynaferd's Avatar
yeah, i'm curious too, and was wondering if i should do that or remove the airbox and use a clamp on, but i do ride in mud and water alot too, so any input is appreciated
Old Oct 19, 2000 | 03:20 PM
AKScrambler's Avatar
I've done the airbox mods, but it was at the same time as installing the entire RCR Stage 1 kit. So I can't tell you how much of the incredible difference is due to the airbox. It consists of
1. Cutting a 1" hole between (but higher than)the 2 exhisting intakes.
2. Cutting a hole or removing the "divider" inside the airbox.
3. Either removing the upper intake boot or cutting it and inserting a pipe with a bigger diameter (splash protection) to allow more flow.
4. Adding a taller UniFilter and using only the outer lid.
You may need to re-jet. I'm not sure. Good luck.
Old Oct 19, 2000 | 05:47 PM
Xplor's Avatar
I have done the mod and the difference is very noticable. I can actually feel the motor breathing better. Makes much more power now. I will try to e-mail a picture that someone sent me a while back. He might even respond himself to your post.
Just remember to do the whole mod and not only part. I added the bigger pvc pipe but did not cut a 1" hole between boot and box. Once that hole was cut, the airflow seemed to have doubled. I did not re-jet because I had already done it for the HPD pipe.
Good luck.
Old Oct 26, 2000 | 07:11 PM
Steve10's Avatar
Did you find the picture...if so please post.
Thanks,
Steve
Old Oct 26, 2000 | 11:25 PM
TheQuadfather's Avatar
The picture and a quick explanation is on the way.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
mbriggs
Sep 13, 2015 10:47 AM
1ArmBandit
Sep 8, 2015 08:59 PM
