RAPTOR 660R turbo charged!!!
Old Aug 15, 2005 | 02:13 PM
dreamMACHINE's Avatar
Default RAPTOR 660R turbo charged!!!
heya, i was reading on sum web page about turbo chargin a 660 raptor, its said to double your horsepower as his raptor put 72 horses on to the back wheel, has anyone one else heard this an has anyone one own a turbocharged raptor or ridden one? if so what are they like? i bet it would give eery quad a run for its money!!!
Old Aug 15, 2005 | 06:23 PM
UBETRUN's Avatar
There is one in AZ that's running a KMS turbo and fuel injection. I understand it's wicked fast but not consistent. Maybe the new Raptor's fuel injection system is better suited for a turbo? Without fuel injection, you have to pressurize the carbs.
Old Aug 15, 2005 | 09:28 PM
ItalianStallion's Avatar
And it's for sale...so if you have about 10 grand in spare change...you can own it. The turbo kits are around $4500.00...KMS says he puts out about 82 horses with it...I saw it run...It screams on the top end....and sounds cool also.
Old Aug 15, 2005 | 09:38 PM
biguns's Avatar
turbos generally double the hp on any motor, sometimes triple, i can put the banks twin turbo on my 5.7 vortec gmc and get up to 750 hp depending on the boost i run.... thats from a 285 stock.
turbos are amazing on anything
if you have connections to a metal/machine shop & shop you can do it yourself, modify the manifold bend your tubes, and there you are doubling your hp at 1/4 the price, the turbos are not that pricy garrett are known at the leading manufacturer and the best, they have the more choices
Old Aug 15, 2005 | 10:19 PM
CTracingraptor's Avatar
give Kelly at KMS Performance a call, he'll hook you up with a raptor that runs 83h.p. on a stock pipe. 602-442-4340. This is a excellent set-up and is hella fast i've seen it run, it kills everything, when it hooks up. And this set-up is reliable and sonsistant when you change the rod of course.....
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
