RAPTOR 660R turbo charged!!!
heya, i was reading on sum web page about turbo chargin a 660 raptor, its said to double your horsepower as his raptor put 72 horses on to the back wheel, has anyone one else heard this an has anyone one own a turbocharged raptor or ridden one? if so what are they like? i bet it would give eery quad a run for its money!!!
turbos generally double the hp on any motor, sometimes triple, i can put the banks twin turbo on my 5.7 vortec gmc and get up to 750 hp depending on the boost i run.... thats from a 285 stock.
turbos are amazing on anything
if you have connections to a metal/machine shop & shop you can do it yourself, modify the manifold bend your tubes, and there you are doubling your hp at 1/4 the price, the turbos are not that pricy garrett are known at the leading manufacturer and the best, they have the more choices
give Kelly at KMS Performance a call, he'll hook you up with a raptor that runs 83h.p. on a stock pipe. 602-442-4340. This is a excellent set-up and is hella fast i've seen it run, it kills everything, when it hooks up. And this set-up is reliable and sonsistant when you change the rod of course.....
Alex Rodak
09-12-2015 09:39 AM
