Belt light came on twice in 3mi.
Old Aug 17, 2005 | 10:38 AM
asnowmobiler's Avatar
Default Belt light came on twice in 3mi.
Last night I was doing some plug checks and my belt light came on,so I limped it home,found the reset in the manual,did the reset took it for another ride and it ran fine then thelight came back on again Any ideas on what I should check first? I'm going to make sure the wires and connectors are ok tonight.
Update: I checked all the connections last night,they all seem ok,I shook the harness with it running trying to get the light to come on. It did not come on,so I took for a ride,it came on soon after I nailed the throttle,it did it three more times in less the a mile. I check my belt deflection,it's at 1in when the belt is pushed down hard. I can see where the belt has rubbed on the little plastic deflector near the belt trip switch and I see a mark on the belt where it rubbed on that peice.
The belt switch was not tripped
Old Aug 17, 2005 | 11:57 AM
alwaysride's Avatar
you might wanna take of the belt cover and check the belt and the belt switch if you havnt already.
Old Aug 17, 2005 | 02:57 PM
trailblazermudrunner's Avatar
from a dead stop when you punch the throttel does the betl squell? if so the belt need to be eithere changed or the clutch need to be shimed does the same on my p 360
Old Aug 17, 2005 | 03:29 PM
No, the belt did not trip the switch and the deflection is within spec.
Old Aug 17, 2005 | 10:15 PM
WVHillbillyWTF's Avatar
Got you on Nyroc's.
Old Aug 18, 2005 | 12:33 PM
Last night cleaned all the connections and put NEW grease on them,also found one connector that I never put grease on before,took for a ride and it did not come back on.
Old Aug 18, 2005 | 09:23 PM
piggers's Avatar
hi-have a '06 700 praire,lite came on,limped home,found connection loose,unlike your manual,mine tells me i have to take it to dealer.dealer not too helpful,won't tell me how to reset,i'd have to leave it there for a week,as i can only get it there on sat & they don't do service work on sat!!!not to mention it runs so poorly it won't make it up the ramp into my truck!(guess i'll install that $69 winch)...or someone out therecan tell me how to reset the darn thing THANKS ANYONE!!!!!
Old Aug 19, 2005 | 05:11 PM
Here ya go.
Make sure the belt switch in the ON position. Locate these connectors: Behind the plastic just below the shifter and forward of the fuel petcock a gray 4 pin connector and a black 4 pin connector. These connectors are held up by 2 flexible metal clamps. Unbend the clamps and pull the wires down where you can get to them easily. There is a black rectangular box on top of the CVT cover. This is the belt trip switch. There is a wire coming out of it with a black 2 pin connector attached.
This is straight from the manual in layman’s terms.
1. Make sure the ignition is OFF.
2. Unhook the black and gray 4 pin connectors. Hook black to gray and gray to black.
3. Turn the ignition ON.
4. Unhook the black 2 pin connector coming from the belt trip switch.
5. Let the belt light flash for at least 5 seconds. More than 5 seconds is OK.
6. Turn OFF the ignition and wait a few seconds to let the KEBC do its thing.
7. Turn the ignition back ON.
8. Let the belt light flash for at least 5 seconds. More than 5 seconds is OK.
9. Turn the ignition switch back OFF.
10. Reconnect the black 2 pin connector, disconnect the mismatched black and gray 4 pin connectors, reconnect the 4 pins to their proper mates.
11. Turn the ignition ON. The belt light should not be blinking.
12. Stow the wires back under the clamps and bend them to secure the wires.
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
