biggest tires on a Sportsman?
Old Oct 19, 2000 | 10:48 PM
BLH's Avatar
BLH
What are the biggest (hight and width) tire on stock rims, without a lift kit? Whats the biggest you have? Thanks
Bruce L. Hall
Old Oct 19, 2000 | 10:53 PM
Xplor's Avatar
From the shopping I did I found that 26" was the top on stock rims. The 27" tires were on after-market rims. As for width I think you can go up to 12.5" rear...not sure up front though.
There are definately people better informed than I, to specify the right answers.
Brian
Old Oct 20, 2000 | 01:08 AM
TxDoc2's Avatar
Search and ask Gregisms. He is "Mr. Sportsman". He knows the mods and the capabilities of the bike very thoroughly. Check out his pics, also.
Old Oct 20, 2000 | 04:59 PM
gregsims's Avatar
It is hard to say which tire will definitely fit without rubbing in the front. I did no research which tire will fit the stock rims, But I do beleive you can go 27 Tall 12 wide in the rear, and 25 Tall 9 wide in the front. You can probably run 26 tall 9 wide in the front with aome tires, but not with others. The rubbing would probably be minor though. If you go 10 wide in the front, you may have to use washers as spacers to keep the front right tire from rubbing the tie tod end.
Greg
Jmuddin284
Jan 19, 2026 07:16 AM
SDR-II
Sep 29, 2015 01:06 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
rcappie4
Jul 18, 2015 07:51 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
