Piped without jets?
Old Aug 18, 2005 | 09:53 PM
2FAST4U69's Avatar
Default Piped without jets?
I just put my pipe on last night and havent jetted it yet. When I got home from work today I started it up and took it down the street and back, then parked it. It ran fine. then about 45 mins later I went to move it to my backyard and it would only idle, whenever I gave it some throttle it killed. I know its because of the jets, I just wanted to make sure I didn't do any damage to the internals. thanks,
scott
Old Aug 18, 2005 | 10:27 PM
04Raptor350Guy's Avatar
If it was fine and then it went crappy all of a sudden without warning.. thats not right, maybe did you leave your parking brake on? Or something to do with the reverse rev limiter maybe.
Old Aug 18, 2005 | 11:16 PM
Raptor660Rshee350's Avatar
When you put high flow headers on a quad you should re-jet, beacuse you are going to have more airflow. So just re-jet......................did you run out of gas lol
Old Aug 19, 2005 | 03:38 AM
2FAST4U69's Avatar
Nope didn't run out of gas... lol. I know it's because of the jets and stock intake still on it. I just want to reasure myself that I didn't damage anything. I only ran it for about 4 mins total. It idle's fine, it's just when I give it some gas, it bogs down and pops a little bit then dies.
Old Aug 19, 2005 | 11:40 AM
Sexy99Warrior's Avatar
Just re-jet..you'll be fine.
Old Aug 19, 2005 | 03:14 PM
86LT250RFatty's Avatar
if it ran great for 4min and then stoPed working corectly like your decribing, its definatly more then the jets, or you would of had those smpthoms from the begining. see if your carbs poped off the boots....
Old Aug 19, 2005 | 05:19 PM
zslate's Avatar
I would jet and try it. You need to anyhow. So that way you would know for sure.
Old Aug 19, 2005 | 06:08 PM
yamahaandchevysgeterdun's Avatar
Check to make sure the floats didnt get stuck closed/open. Tap on the bowl with the end of a screw driver.
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
