Kazuma Falcon 110 has lost spark
My sons Falcon 110 has lost spark and I have tried almost everything. I have replaced the coil, rectifier, CDI and nothing works. My friend and I each bought one unit each last December. I have been able to take know working parts off of his quad and put them on mine. I still get no spark. I have replaced the plug as well and I get nothing. Is there a safety swithch that would prevent spark or do I have deeper issues. At one time I could push start the quad but now that doesnt work. HELP PLEASE
Could be the Mag, also try this:
TO BYPASS ALL CUTOFF SWITCHES ON KMX-50, KMX-110, RFX-110
LOCATE CDI
CUT BLACK WIRE WITH WHITE STRIPE CK. FOR SPARK LEAVING ENOUGH WIRE TO RECONNECT.
THIS WILL RULE OUT ALL CUTOFF SWITCHES ON THE ATV INCLUDING: IGNITION SWITCH, HANDLE BAR SWITCH, SIDE CUTOFF (KMX-50 ONLY) REAR CUTOFF( KMX-50 ONLY)
CDI 5 PIN PLUG WIRING DIAGRAM:
1. GREEN- GROUND
2. YELLOW W/BLACK- IGNITION COIL
3. BLACK W/ WHITE- IGNITION KILL
4. BLUE W/ WHITE- IGNITION PICK-UP COIL
5. RED W/BLACK ? STATOR COIL
Hope it helps, Jim
LOCATE CDI
1. GREEN- GROUND
Hope it helps, Jim
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
rjacree
Aug 3, 2015 10:21 AM
