oil change
Old Aug 20, 2005 | 01:25 PM
S10ripper's Avatar
Default oil change
I need some help, i just bought a 2001 raptor and i didn't get a manual with it. how do i change the oil? the directions from the manual would b the easiest. thanx
Old Aug 20, 2005 | 01:56 PM
bk8800's Avatar
Default oil change
hey man, i feel like helping someone today
1. Remove
engine skid plate
2. start the engine and let it warm up for several minutes
3. stop the engine and place a container under the engine oil drain bolt
4. remove dipstick
5. remove engine oil drain bolt (bottom of oil tank)
6. remove engine oil bolt (crankcase) drain oil from the oil tank and crankcase
5. if the oil cartidge is also to eb replaced replace it.
Old Aug 20, 2005 | 03:11 PM
fasterthanyou22's Avatar
Default oil change
no no no. you dont neccesarily have to take off the skid, just have someone turn the reverse **** while you take out the bolt.And you have to drain it from the oil reservoir itself, so that will be easy.Then you have to take off the oil filter with a monkey wrench or the tool for it and there will be oil in there so have a pan under it.
Old Aug 20, 2005 | 07:18 PM
S10ripper's Avatar
Default oil change
and when i button everything up and add the oil i just let the oil go thru the lines or do i have to start it up to get it to suck it into the enhgine? and how do i know when i have enough? when it is fully filled the engine? dry sumps are confusing!
Old Aug 20, 2005 | 07:22 PM
Default oil change
You do have to start it up so it will suck oil into the engine, and be sure to change your oil filter too.and after it sucks some oil in you will have to put more in.
Old Aug 20, 2005 | 11:30 PM
Turtler's Avatar
Default oil change
I like the K&N oil filters, they have a 17mm hex at the end of the filter for easy installation and removal rather than buying some oil filter wrench for the stock yamaha oil filter.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
