RaPtOr CaRbS
Old Aug 21, 2005 | 03:29 AM
CTracingraptor's Avatar
Default RaPtOr CaRbS
So i was getting my bike ready for the drags tonight. She has been sitting for about 3 months, with the ocassional putt around the block. Go to load up the bike, turn the fuel **** on, and fuel starts dumping out of the bottom of my float bowls. Wont stop leaking on until i turn the fuel off... it will fire right up when the fuel is leaking out the bottom? It did this before a while ago then one day it just stopped and hasnt given me any trouble till today? Any help?
Old Aug 21, 2005 | 03:34 AM
yellowrider250ex's Avatar
Did you try geting something and taping the top of the carbs while its running
Old Aug 21, 2005 | 03:39 AM
tapping on top of the carbs? what will that do?
Old Aug 21, 2005 | 03:40 AM
Your float mite be stuck and that should make it knock loose
Old Aug 21, 2005 | 03:42 AM
i shot compressed air down the fuel line and fuel shot out the top, no luck. I allready torn down the carbs down and shot carb cleaner down every f-ing little hole, and the float bowls are not stuck.
Old Aug 21, 2005 | 03:51 AM
Karny's Avatar
My room mate has a 2002 < i think> raptor. His did it once, I took the carb off took it apart and cleaned it really well with some berimans b12 or brake cleaner. Anyhow, clean out the main and pilot jets also. Sometimes dirt gets down in the float bowls the floats get stuck. Compressed air might help but the best bet is to take them apart and clean the crap out of them.
Karny
01 banshee
05 yfz450
99 banshee
Old Aug 21, 2005 | 04:01 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Either your floats are way out of adjustment or the needels are not sealing. It is also possible that the drain screws are not selaing.
Old Aug 21, 2005 | 01:39 PM
raptorider660's Avatar
the same thing happend to my friend its that the floats are stuck and so there just pouring gas cause they manage the amount of fuel to let into the carb but since it is stuck its just pooring out so try to take them apart and check the boles then put them back should fix it
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
