Bogging and Sputtering
Old Oct 20, 2000 | 12:12 PM
rhino99's Avatar
Ok, I took my 250r out to the track to test out some new shocks. At first it was running awesome, but then after a couple laps, it really started bogging down in the whoops, like it was out of gas, but it wasnt out of gas. This I didnt worry about TOO awful much, but then it started doing it every time my front end was pointed down it would just lose power for a second or so then it came back, but when it lost that power I usually was out of the powerband after that and so that kinda scared me that I would go for a big double or something, bog and never get the front end up. We all know what happens then.
So...what is causing it to bog? Is it the carb flooding itsself out? I have read that a Boyesen Float Bowl will fix this, or a carb vent system. Will these work? Thanks
Old Oct 21, 2000 | 08:51 AM
400exalltheway's Avatar
not to fimilar with 250r yet(in process of building one) but was it done fine before you took it to the track. your main jet or something may be clogged. maybe take your carb off and clean it top to bottom.
Old Oct 21, 2000 | 02:14 PM
rhino99's Avatar
Thats what it has to be I am thinking. I thought at first maybe it was the fuel foaming or something, which is what the Boyesen Float bowl is supposed to prevent, but yesterday it ran like crap too, then finally died and would not restart. I will take the carb apart and clean it and see if that helps.
Thanks
Old Oct 21, 2000 | 02:42 PM
let me know how it turns out. good luck
ReconBayou
Oct 31, 2022 05:37 PM
Sassinm1
Sep 30, 2015 04:23 AM
Bernhard
Sep 25, 2015 12:45 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Slagpolaris
Sep 5, 2015 09:41 PM
