2001 660 Raptor rear axel bearings?
Old Aug 23, 2005 | 10:30 AM
Boxie's Avatar
Default 2001 660 Raptor rear axel bearings?
Does anyone know the steps to replace the rear bearings on a 660 Raptor? I am trying to help my son with his ATV and we are kind of stuck! Any guidence would be greatly appreciated.
Thanks,
Boxie
Old Aug 23, 2005 | 10:57 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
wellll,
remove the 2 large horizontal bolts that run thru the bearing carrier
remove the 2 set screws on the outer nut on the axle
remove the 2 axle nuts
remove the cotter pin, nut, collar, wheel and rim from right side of axle (slide the collar right off the splines)
slide the axle out of the swingarm(you may need to coax it with a block of wood and a mallet)(be careful to not ruin the threads on the axle) (the rotor falls off the axle,,,and the chain will need to be loosened completely and taken off the rear sprocket as it slides out as well)
once the axle is out,,,you will need to split the 2 pieces of the bearing carrier and remove it from the swingarm
then you will need to remove the seals and bearing from the inside of the carrier (tricky part)(put it in a 250 degree oven for a while to help loosen them)
when you put the new ones in,,,don't forget the spacer between the bearings
put it all back together,,,,and be sure the axle nuts are tight. (they have a tendency to loosen)
depending on how bad the current bearings are,,,,you may have a little or lot of damage to your bearing carrier (you may need to clean it up a little with a grinder or dremel)
hope you can understand that
Old Aug 23, 2005 | 11:01 AM
Bing's Avatar
Super Quad Patrol
also, do a search,,,,lots of threads related to this
this might help
Old Aug 23, 2005 | 11:10 AM
Boxie's Avatar
Thanks, for your help. I did check threads and could not find anything. Your expaination is clearly helpful!...Boxie
Old Aug 23, 2005 | 11:28 AM
Bing's Avatar
Super Quad Patrol
welcome to the forums
and let us know if you have any trouble
this thread will help
maxjung
Jul 14, 2015 03:10 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
