16mm wide body carb
Old Aug 24, 2005 | 09:25 PM
cvc42's Avatar
Default 16mm wide body carb
I am trying to find a 16mm carb for my 4 stoke 50cc ATV. It came with a 19mm which is to big for the engine. I have been unable to find the carb. It measures 48mm center to center on the intake bolts. Anyone have have a contact for a carb like this? It has a Zongshen motor
Thanks for any help
Old Aug 26, 2005 | 02:42 PM
spike99's Avatar
If I remember correctly, the Polaris 90s (possibly the Scrambler 90s) do use a stock 16mm carb. Wonder if it has the opening you need for your project??? Also, the E-Ton 90s uses an 18mm Carb. I know you were asking for 16mm carbs but 18mm might have the opening size you're looking for.
Hope these ideas help....
Old Aug 26, 2005 | 08:12 PM
cvc42's Avatar
I just found one at Power Bikes USA the problem I was having was getting one to fit my intake which was 48mm center to center on the intake bolts,most are 42mm. Thanks for your input!!!
Nondem
Feb 22, 2020 12:20 PM
rcappie4
Jul 18, 2015 07:51 AM
Riding Gear
Jul 7, 2015 05:03 AM
