still can't find all the zerks of H.O.
I still can't find all the zerks for my SP H.O. total I have 18. 6 on each side of the rear suspension 2 on each side of the front suspension and 2 on the drive line for the front wheels. I was told there are 26 but I can't find them. Do I have to be a genius to find them. Help would be very nice.
2001 SP H.O.
2001 SP H.O.
I can only find 25 on my 2000 SP 500. 7 on each side of the rear suspension(3 out at the rear wheel and 3 where the swing arm connects to the rear housing and 1 on the anti-sway bar for each side. The upper fitting out at the rear wheel is the hardest to find. Take the rear wheel off makes it easier). 3 on the drive shaft to the front(1 slip joint fitting and 2 universal joint fittings). 3 on each side of the front end( 1 at lower ball joint. 1 at the swing arm/frame. 1 at the front axle universal joint). 2 on the steering column( 1 under the fender on the steering column,left side and the other just under the headlight, behind the wiring). Thats all I can find on mine. I'd sure like to know where the 26th fitting is located?
I have found 22 zerks now. 7 on each side of the rear suspension 3 on each side of front suspension and 2 on driveline for front wheels where are the rest of them I cant see any on the steering post like every one said
