400ex oil
Old Aug 27, 2005 | 03:28 PM
400exboy779's Avatar
Default 400ex oil
I have a 04 400ex. Does it have 2 oil resevoirs. I know that u have to fil it at the oil cooler but i know that it has the bolt on the side of the crankcase that u have to check. I really need help quick on this so can sumbody please reply. Thanks
Old Aug 29, 2005 | 04:44 AM
Wreckless400ex's Avatar
Default 400ex oil
well when i change my oil on my 400 i drain all the oil out of the oil tank then drain it out of the motor bolt on the side, then unbolt the oil filter change it out bolt it back on but the bolt back in the side of the motor and the one in the oil tank fill it up till it shows then start it for about 10 seconds turn it off and check it again and add till it shows. and then it usually stays about right. hope this helps
Bill
Old Aug 29, 2005 | 10:01 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Default 400ex oil
Wreckless said it all pretty well. The oil tank will take a little less than 2 quarts. When you start the engine the first time, the oil level will go way down as it fills the oil cooler, crankcase, and oil filter. I start the engine, ride it around slowly for a minute or two to be sure the oil gets distributed throughout the transmission, then I stop it and top the oil level back up.
Do a search, and you will find lots of posts on what are the better oils.
Old Oct 27, 2005 | 04:27 PM
400EXtreme1's Avatar
Default 400ex oil
i always wonder bout this? another question? If you use one oil then drain it nd use another is it bad for it?
Old Oct 28, 2005 | 09:20 AM
Red Rider
Default 400ex oil
The modern oils are all compatible. I highly recommend an ester synthetics over any petroleum oil or PAO synthetic.
Maxima Extra: http://www.maximausa.com/
Old Oct 28, 2005 | 10:31 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default 400ex oil
Just as long as it is an approved motorcyce oil it will be fine. I used to run normal motor oil, while nothing ever failed, it did shift a little rougher so I swithced to motorcycle oil.
Old May 28, 2006 | 09:51 PM
jed250's Avatar
Default 400ex oil
I've got a question concerning 400ex oil. Rather than making a new thread, I thought post it an old one...
What kind of oil should I use? Should I use 5W30? 10w30?
-Jed
Old May 29, 2006 | 12:35 PM
Red Rider
Default 400ex oil
See this post, and your owners manual: http://forums.atvconnection.com/mess...ighlight_key=y
I would use: 5W30 for very cold winters, 10W40 for in between, and 15 or 20W50 for very hot summers.
Again, I highly recommend Maxima Extra!
Old May 29, 2006 | 03:44 PM
ubertrailblazer01's Avatar
Default 400ex oil
some notes on oil:
yeah, ive always ran 5w-30 in winter, and i run premium too (regular ran like crap). though i should have rejetted... the temperatures range from 35F to -30F (though i havent rode in anything below -20F yet). i run 10w-40 in the summer (anywhere from 50F to 75F usually).
and make you you DONT OVERTIGHTEN YOUR OIL FITLER SCREWS. those things are small and will break easily. one of mine broke off 2 winters ago and i duct-taped the cap to make sure it wouldnt fall off.
Old May 29, 2006 | 04:07 PM
jed250's Avatar
Default 400ex oil
Originally posted by: ubertrailblazer01
some notes on oil:
Well, I bought 2 quarts of pennzoil 10w40 today. Also, I picked up an oil filter at Canadian Tire. This is gonna rock!
