Are 28" tires too big for a Honda Foreman??
Old Aug 27, 2005 | 04:22 PM
Yam4Life660R's Avatar
Default Are 28" tires too big for a Honda Foreman??
I am looking to buy a '03 Foreman, and it has 28" tires on the front and rear. Is that going to be too big, or will I have problems out of it? Will they rub or anything like that? It has wheel spacers if that makes a difference. If not, what are they? The guy that owns it said he made a snorkel for it, but I want to get rid of it. When making a snorkel, do you have to cut anything? Basically, can I just remove it without any problems?
Thanks,
JE
Old Aug 27, 2005 | 06:00 PM
yellowrider250ex's Avatar
he prolly cut a whole in the plastic for the snorkle. and i've seen 28s on a eiger
Old Aug 28, 2005 | 12:19 AM
Where on the plastic are you talking about?The exterior panels or the airbox?Either way if it's been cut i'll probably not be interested anymore.
Thanks,
JE
Old Aug 28, 2005 | 12:21 AM
the body plastic
Old Aug 29, 2005 | 11:14 AM
action450s's Avatar
28's with no lift are probably rubbing...the snorkle needs a hole cut in the fender under the rack for the pipe to come up, and a little trimming in the inside fender. No big deal...if its a good job done on it, I'd leave the snorkle on it. I just fininshed one for mine and it works great.
Old Aug 29, 2005 | 02:49 PM
It says in the add that it does have a lift kit.Does that eliminate the rubbing?
Thanks,
JE
Old Aug 29, 2005 | 02:57 PM
action450s's Avatar
Pretty much, and if it has wheel spacers too then I highly doubt there's any problems.
If your looking at buying, have a buddy lift up the quad and shake every wheel to check for worn wheel bearings. Bigger tires will wear bearings faster. They're not overly hard or expensive to replace, but it could be a point to haggle the price down a little. Also ride the bike in 4wd and make very sharp slow turns. If you hear any ckicking from the front end, there may be a side axle on its way out.
Old Aug 31, 2005 | 01:46 AM
Hey man thanks for the tips.I'll definatly check those things whenever I get ready to buy.Apparently the guy with the above Foreman must have sold it because all of the sudden I can't get a hold of him at all.Oh well,i'm sure i'll find another.I was a little hesitant about that one anyways.Made my decision easy.
Thanks again,
JE
Old Aug 31, 2005 | 04:50 PM
trav300ex's Avatar
You can turn them but will need a full things. Uni, jet kit, hmf utility, body lift and snorkel. That will wake your quad up, and give you more ground clearence and ability to get through the nasty stuff.
greg74
Sep 10, 2019 03:03 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
