what low priced parts can i buy to make my 2000 300ex faster??
Old Aug 28, 2005 | 03:15 PM
300exrider666's Avatar
Default what low priced parts can i buy to make my 2000 300ex faster??
just got this 300ex...its all stock, but its no where near fast enough for me..what kinda little odds and ends can i get for it that will give it a little more power? I Have a 2 brothers exhaust coming for it but i dunno what else to order..anyone? and also, the thing wants to flip badly when i hit bends, will i notice a difference if i put on wheel spacers? (5 inch)
Old Aug 28, 2005 | 04:57 PM
blastereatin250ex's Avatar
You can take of the airbox lid, rejet, and get a drop in cam all for about $140. I wouldn't get the wheel spacers if you plan of jumping real high. But otherwise they would probably be okay.
Old Aug 28, 2005 | 06:56 PM
drag101's Avatar
if u alrdy have a silencer comeing try a dyno jet kit with it and for stability try a new durablue axil on the rear and some spacers on the front
Old Aug 28, 2005 | 08:37 PM
TehWarriorGuy's Avatar
For free you could just take the airbox lid off
Old Aug 28, 2005 | 09:08 PM
95wolv's Avatar
For 60 - 80 bucks, you can pick up a racing cdi from ebay, it will let you rev out more on top, also, you can find some 400ex a arms and shocks, you can widen the front end, and get about twice as much travel, you will just need to relocate the top shock mounts, you can get a kit off ebay, or if you are handy with a welder, make some of your own. A 2001 rear raptor shock will give you 1" more travel on back, and give you compression/rebound adjustment with a remote resivoir, a lot cheaper than an aftermarket shock. The stock exhaust is very small, with your new pipe coming, you can probably go up 1 or 2 jets on the main, and one on the pilot, Hondas are jetted pretty lean, and are cold blooded, jetting up helps a bit. Either put some holes in the air box lid, or run an Outerwears screen cover, that will keep the junk out while flowing like no lid. The stock set up only draws air in through 2 little frame tubes, so the air box is a major restriction. With my son's set up, the wider 400ex front end,and the 1.5 " spacers on each side on the back, it corners great, and takes rough stuff and jumps a lot better. I used to be able to leave him way behind on the trail, now he can keep right up with me. All this won't be too bad of a price if you watch ebay, swap meets, or nose around salvage yards for parts, or buddies who are upgrading and have stock parts they want to get rid of.
Old Aug 28, 2005 | 09:23 PM
Redripper's Avatar
sorry to get of subject, but blastereatin250ex were did you get your powerlid (what brand???) and what is your jet size?
Old Sep 6, 2005 | 05:52 PM
i Didnt get a 'powerlid'...i went out and bought a K&N air filter and just took the lid off...prolly not the best idea...been running a little funny since then, prolly gunna take off the filter an put just drill sum holes in the lid...
Old Sep 6, 2005 | 05:57 PM
Redripper's Avatar
i said blastereatin250ex not you!!!!!!!!!!!!!!!!!!!!!!!!
MikeyBoyesq
Nov 27, 2020 02:44 PM
fullprice54
Jun 18, 2015 09:44 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
wbfjim
Jun 8, 2015 06:20 PM
