Fastest Blaster..
Old Aug 28, 2005 | 11:19 PM
BlasterDisaster117's Avatar
Default Fastest Blaster..
If you were looking to make your blaster fast... what would you put on it? Me and My friend are having a little agrument... i think u would bore out .50 over get a big bore kit ... what do u guys suggest?
Old Aug 28, 2005 | 11:38 PM
YFZ450kid's Avatar
I'd go with a high compression kit before boreing out that far... besides the usual intake and exhaust mods, Stroke it, I think you can get those up to about a 230-250 cc off of a good stroker kit. and if you want faster top speed (overall top speed not acceleration) change up the final gearing.
Old Aug 28, 2005 | 11:41 PM
well is a big bore kit worth putting on a blaster
Old Aug 30, 2005 | 12:46 AM
YBlasterboy's Avatar
What kinda riding do u do?
Old Aug 30, 2005 | 12:48 AM
Air's Avatar
Air
Put a Vitos 240 kit on it and gear up.
Old Aug 30, 2005 | 01:32 AM
Speedster700HP's Avatar
Try different mixes of race gas if you go with higher compression especially----maybe a 50/50 mix of 100 and 93 first, then try pure 100 octane, etc, depending on how radical your build up is.
Old Aug 30, 2005 | 05:48 AM
dreamMACHINE's Avatar
if you got big $$$$$ to spend, then you should put a turbo charger on it. it doubles your hp.
Old Aug 31, 2005 | 03:48 AM
TrXFoFiddyR's Avatar
That sounds sick
Old Sep 1, 2005 | 02:03 PM
That sounds sick
sick??? eh?? dont get you?.........................
Old Sep 1, 2005 | 02:56 PM
lethaface's Avatar
Not trying to argue with you but there is much better kit's out there than the Vito's..
If money isn't a option a CT sonic kit would be the way to go..The kit comes with a new ported cylinder, a right side pipe, a 36 or 38mm carb and a few other things..This kit has been dyno'd in the low 40hp range to the rear wheels..But the beauty of it is there is still room for a motor builder to improve on the cylinders design..Have the kit head milled for some serious compression and hang on :-)
