Fastest Blaster..
If you were looking to make your blaster fast... what would you put on it? Me and My friend are having a little agrument... i think u would bore out .50 over get a big bore kit ... what do u guys suggest?
I'd go with a high compression kit before boreing out that far... besides the usual intake and exhaust mods, Stroke it, I think you can get those up to about a 230-250 cc off of a good stroker kit. and if you want faster top speed (overall top speed not acceleration) change up the final gearing.
if you got big $$$$$ to spend, then you should put a turbo charger on it. it doubles your hp.
Originally posted by: TrXFoFiddyR
That sounds sick
Originally posted by: Air
Put a Vitos 240 kit on it and gear up.
If money isn't a option a CT sonic kit would be the way to go..The kit comes with a new ported cylinder, a right side pipe, a 36 or 38mm carb and a few other things..This kit has been dyno'd in the low 40hp range to the rear wheels..But the beauty of it is there is still room for a motor builder to improve on the cylinders design..Have the kit head milled for some serious compression and hang on :-)
