250r carb
Old Aug 30, 2005 | 04:07 PM
dirtrider250r's Avatar
Default 250r carb
I'm looking for a little help here, I got a carb rebluid kit with slow jet#72, main jet #142 rad valve,and fmf pipe. and with all this my bottom end sucks it doesnt even hit power band till like 3rd gear i know i have a carb problem but i cant figure out if the carb just needs to be ajusted or the jets are wrong, i'm also running 40:1 gas with klotz R50. Its also smoking alot too i just changed my packing. Maybe the rings are shot?
Old Aug 31, 2005 | 04:57 PM
bigblock2stroke's Avatar
Default 250r carb
Do a compression check for the rings.
A lot of things can cause loss of low end torque.
I've not heard good things about the FMF Fatty. Do you have the stock pipe to see if it makes a difference?
Reeds can also affect torque. Reed spacer might help.
It is a 2 stroke, so its a top end freak anyway.
Is your gearing stock? If its geared for top end, the first couple gears will be really slow.
Is the carb stock? are the plugs fouled.
Not saying any of this is your prob, just thrwin stuff out there
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Dustinyoungs
Jul 24, 2015 07:18 AM
Aitch
Jul 21, 2015 09:40 PM
CRamshaw777
Jul 18, 2015 05:46 PM
