Flippin' flat tires....is it the rims?
Old Sep 1, 2005 | 02:30 PM
RJF's Avatar
RJF
Default Flippin' flat tires....is it the rims?
I keep having problems with my tires getting low. I took one in the shop and they said it was a dirty bead. I've got the same tire leaking again along with both in the rear. I've been having to go through a lot of mud lately and I can't find ANY puncture wounds.
Do the beads get dirty easily with stock tires and wheels? Would aftermarket alum. wheels help a lot?
I've got a 2004 Scrambler.
Old Sep 1, 2005 | 04:35 PM
MnFriesen's Avatar
the mud can get between the rim and the tire, and then drys causing a break in the bead....so that is probably your problem
Old Sep 1, 2005 | 05:30 PM
RJF's Avatar
RJF
Is this very common with these rims? Would a set of aftermarket wheels help prevent this? Which ones?
Old Sep 9, 2005 | 03:14 PM
greenlant's Avatar
i had the same problem with the stock rims and tires. I ended up getting 25" Holeshots Atrs on series 5 ITP wheels. Mostly for the riding I do, but was sick of pumping up flats. My new tire/rim combo doesnt have a problem. The stocks must not have a great seal on the bead. I dont think aluminum rims would fix it, but new tires probably would
Old Sep 9, 2005 | 04:37 PM
RJF's Avatar
RJF
I think I am going to go with ITP mud lights in the rear and front with their C series aluminum rims. Stock size tires since I slide around a lot and like the look of the smaller fat rear tires. When my 489's are worn out of course.
Old Sep 9, 2005 | 05:05 PM
greenlant's Avatar
basically what i have except substitute mud lights for holeshot atrs. check out my site, i have pics with the bigger tires. best hop-up for the scrambler in my opinion
Old Sep 9, 2005 | 06:17 PM
rieds's Avatar
if you ride in rocky area's like creek beds a lot you don't want aluminum rims.
Old Sep 10, 2005 | 12:37 AM
greenlant's Avatar
why not. steel rims will bend easier, aluminum tend to crack but normally requires more force to do it. i nailed a big (2' round) rock about 15-20mph and didnt mess up either the tire or rim. aluminum is the way to go if you have the money
Old Sep 10, 2005 | 01:05 AM
Polaris500HO4x4's Avatar
you are correct but the alum. rims will crack before a steel rim will bend enough to not hold a bead
Old Sep 10, 2005 | 01:16 AM
RJF's Avatar
RJF
I don't get near rocks. I like Aluminum for a rim material, always have. I've got 16.5x14" Weld rims on my K5 blazer and the factory alums on my Ram Cummins. I like alums. Plus, they are lighter and might improve mileage/braking/acceleration by a marginal amount, as long as I go with a tire that weighs the same or less than the factory tires. Every little bit helps. I like the look of aluminum too, steel is ugly.
