Wolverine Carb help.
Old Sep 4, 2005 | 05:59 PM
fordmustangfan67's Avatar
Default Wolverine Carb help.
Can someone please tell me how to change the needle setting on my 2004 Wolverine. Thanks guys!
Andy
2004 Black Wolverine
HMF Slip-on powdercoated red
k&n filter
Warn 424 Select
Old Sep 4, 2005 | 06:09 PM
Raptoraintdoinsogood's Avatar
if anyone can tell him this maybe you can tell me how to sync up the carbs on my 660r
Old Sep 5, 2005 | 02:03 AM
2001Warrior430's Avatar
After you remove the carb, there should be a plate on the very top.Under that plate is your "piston" with an arm and a spring attatched. Remove the screw on the arm, opposite the side of the piston, rotate arm up and slide over. There are two screws atop the piston, undo those and the assy will be removable.Move clip up for lean and down for rich....Dont lose the small washer under the clip when you remove the needle. You can also go to ronnies.com for a microfiche diagram of your carb...
randycraft24c
Aug 5, 2015 02:50 PM
micheleLeigh
Jul 12, 2015 02:50 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
